Here is an old pic. of mine. 2 3/4" of lift with 31's. Only rubbed on the control arms. The 31 Trxus are the same as most 32's, so you should be fine with a 3"/a little trimming & the right BS. JIM.
chris did u do any therapy in st.louis at the rehab institute?
my wife is a pt there working on spinals.
any progress with the stem cells. email me at [email protected]
awesome it looks like my tires and lift will work. once i get outta china i can start the install!! hopefully i can still be able to get my crippled ass in it. haha
just incase you're not aware of it, be carefull trimming the rear. you don't want to cut past the spot welds, or your wheel well will seperate. most people cut to just before the welds, and then make vertical cuts between the welds and hammer the rest over.
I agree. If you can avoid cutting before the spot welds that would be best. If you went "Big" down the road. You could cut past the welds if secured the area with large diameter rivits. Thats what I did when I moved up to my 38 TSL's. My thoughts and prayers are with ya on your recovery. :wave1:
