karter74
- Longview, TX
Hey guys, I have rebuilt the engine in my 87 cherokee and let me tell you, new problems have popped up everywhere. Most are minor, just very annoying. First, the fuel injectors leaked where they connected to the fuel rail, I bought new o-rings for them, but fuel injector 2 still seeps a little, i'll just have to figure that out. Then once i got the fuel injectors to stop leaking(other than #2) i found that the FPR leaks where it was attached to the fuel rail. One new o-ring later and that was fixed also. Then the return line to the FPR started leaking, so i bought a new connector for the end of it and that was fixed. Anyway, the newest and biggest problem I have is i am not getting any spark from the coil itself. I am pretty sure its not a ground wire problem because everything else works electrically like the fuel pump, starter, etc. I was wondering if anyone knew what wires are critical to the coil so i know what to look for, as the motor cranks and has oil pressure, just no spark to the distributor.
