I had posted about my temp problems on another thread that some may have not read so thought I would start a new one here.
I have had trouble getting a stable temperature since my radiator change. Thought must be the thermostat which was a Robert Shaw one so tested in on the stove with a thermometer and it opened and closed perfectly and the same as the brand new one I had in the pan with it. So fitted the new one anyway but no difference. Once the thermostat opened at the right temp, it just had trouble closing it again I think due to the high flow of the new radiator combined with my high flow Hesco water pump. So tried just a standard one which improved it some but still had a similar problem. Did some thinking about it and thought I had too much flow. So I thought of fitting a restrictor in the upper radiator hose at the radiator end. Normally restrictors are used instead of a thermostat but couldn't see why both couldn't work together.
Well I happened to have a brass washer the right size to try first with a 5/8" hole and 1.33" or 34 mm outside and it made no difference. Too close in size to the standard thermostat opening.
So I tried a Rancho urethane upper front shock pin bush. It had a 3/8" hole which I thought might be too small even though the company I spoke to had gone as small as this to improve cooling by raising the block pressure. So I just put a drill bit in the vice and then screwed the bush over it to open it up to 1/2".
Well once the thermostat opened at the right temp, it just sat there idling with no fans at all ( I have twin electrics ) running with 24*C/75*F outside temperature. I had to bring the revs up to nearly 3000 before the temperature rose and the fans came on and cooled it straight back down. The needle fell until the fans switched off and then just sat there again. So it has been a success so far with a nice stable temperature at 190*-195*F with the fan coming on much later in time than before. This is showing the extra pressure inside the block and slower flow through the radiator is giving better heat transfer.
So this is something worth trying to get improved cooling and only takes a few minutes to drop a restrictor in. The reason it works is that greater pressure inside the block stops the coolant boiling off the cylinder walls andinside the head and the slower flow through the radiator gives more time for better heat transfer. You just need to try what hole size works best for your water pump, radiator and thermostat combination.
Since posting this else where yesterday a couple of people have contacted me and said that some old Mustang's and Audi's had a restrictor in the heater hose to boost the heater. When some replaced the hose and didn't know they had to swap the restrictor over as well, complained that their heaters were not working as well any more. This shows the better heat transfer with the slower flow.
The company I got some if my ideas confirmed with builds Nissan Patrols ( www.ontrack4x4.net.au ) used in the Outback and Winch Challenge events etc. Some are even turboed petrol's and they found getting to block pressure up to 16 psi ( like you radiator cap but that is only up there when around 125*C ) transferred the most heat. They needed to use high flow water pumps to get it that high but that is not to say restricting a stock setup with a Jeep pump you cannot improve the pressure enough at least to help.
