NEW Bushwacker Cut-Out XJ FENDER FLARES
XpedientJ
MA
New-in-box set of Bushwacker Cut-Out fender flares for 4-door Cherokee XJ. This is the set designated for -86-94, but I did speak with Bushwacker prior to purchase, and they said this is also the set they recommend for post-96...and, although they did say that some minor cutrting may be needed for fit on post-96, I did not see where that would be the case, certainly on the front ones where I gave full scrutiny.
Unfortunately, the prior owner of my '99 did a full cut-out to accommodate Tj flares which. given the squared configuration of the TJ units, has left a void in the upper-front area should I use the Bushwackers...and, with all else I still need to deal with...I have, reluctantly, decided to forego for now...
Thus, I opened the box and removed a front flare, held it up to make the fit determination...so, these are absolutely as-new/unused. Lookin' to get $340. Will be pleased to ship, at actual cost. Located in Foxboro, MA.
Will ship at no extra charge...! Hate to have can't-use parts sitting idle, when someone can put 'em to good use...:)
Wish I was in a position to give 'em to you....:) Actually, they just recently sold on ebay... Hope you can find a deal on a set.
