New Alloy-USA 33 spline shafts
Matt98XJ
I have a pair of brand new Alloy 33 spline shafts for D44. Has wheel bearings, seals, and lug nut studs in the kit. $200 firm plus shipping. I can also get a new 33 spline Detroit or ARB if needed. Located in Everett Washington.
are the bearings set 20, the larger bearing 44 with the 9'' ends ifso im interested///Kevin
Yes its for the XJ 44. I don't believe its the set 20's but I'll find out. You do have to use the stock retaining plate, which will have to be taken off the stock shafts.
