Do lots of research and figure out a plan for the vehicle instead of throwing money at it.Do lots of research and figure out a plan for the vehicle instead of throwing money at it.
Need I repeat?Do lots of research and figure out a plan for the vehicle instead of throwing money at it.
Edited to include the last of my post. Somehow it got cut off.Thanks for the brutal honesty but "BENT's" needs are not my needs.
20 years ago, the 97-01 xj's were not at end of life cycle. And for as many xj owners, notwithstanding nuances inherent to different models over the years, seeking to improve their rigs, considering my needs notably at the minimalist end of the upgrade spectrum, I hardly think they pose such an out-sized System Integrator level effort for a few more dollars (I mean a couple more inches), I mean a simple MOD.
So far, I haven't heard anything that tells me the total solution goes beyond perhaps motor mounts and a SYE and custom drive shaft, TO DO THE WHOLE JOB. And I do appreciate the reasons provided by RCP Phx posted above - thank you (now I have a clue about the small fluid leak on my garage floor between the Transfer Case and Front End along the driveshaft) that I never saw before.
But to continue with the brutal honesty, that information should't take 18 months of research when the money that's being laid on the table is not opposed to doing what it takes if you get my drift. And with no negative reflection on enjoying the freedom of the offroad genre, I am sadly beginning to get the impression that the Jeep MOD Industry hasn't advanced beyond a bunch of cottage industry piece-part vendors.
Is there anything else that someone new to the Jeep Mod world should know about doing a simple 3" LIFT?
I did a search onThat's the point, and you're welcome.
Nominated.
Only the HD ones, h-n-t's are the factory 27 spline.Does that mean all SYE Mods (242 T-case) provides the better 32-spline result?
You need a std HD output shaft not a short shaft kit that doesn't have a speed gearWhat is it about that kit that will not work? I have no vested interest in doing the wrong thing. I have another shop that would install parts I buy in addition to this particular shop that made the recommendation. At this point, I would rather do the SYE modification to get the clearance. But am I buying into more problems? Although they are totally unrelated, they have a clear sourcing channel to Iron Rock but were sour on H-N-T options... Please advise...
