brandon11130
- Bethlehem PA
ok i would like to run 33's but i live in PA and here you must have the tire covered by the fender. there are 2 things i can do tell me what you think
1. run a 33x10.5 on the stock rims, i have been told they will work and not rub, any experience? i know they will look thin but i have seen it before and i dont think it looks that bad.
2. get the most backspacing possible to run a 33x12.5, with out rubbing, 4.75? 4.5 on a 8" rim. what is the most backspacing i need so that i dont rub it on the control arm?
i will probably get 4 rear TJ flares and that should help a little but it only helps cover an inch or more. , right?
