pityocamptes
- SW
I currently have a 1974 Scout with the AMC 258 and T-18 tranny. My current engine gave up the ghost, so I have been kicking around either swapping in an AMC V8 or a 4.0 stroker. Here are some questions I have that hopefully someone here could help me with. Thanks.
1. Will the 4.0 stroker (4.6-4.7L) directly bolt onto where my current AMC 258 is, and use the same motor mounts, bellhousing, clutch, flywheel, etc.?
2. Will the vast majority of parts, dizzy, water pump, timing cover, oil pan, etc. be a direct bolt on from my AMC 258 to the 4.0 block?
3. I contacted Russ in Covina, CA, (Bishop-Buehl Racing Engines) and he indicated that the stroker with shipping, core charge, etc. would run about 3300-3400. Is that a decent price? if not, any other recommended, quality shops?
4. Finally, what could I get if I sold my current engine on craigs list if I include the intake, exhaust, new weber 32/36 carb valve cover, extra parts? Would like to recoup some of my costs.
Thanks again!
atriot:
Thanks again!
