Flickr apparently won't give you BBcode or even a URL for a direct link to JUST the image if you're using a mobile device. I had to pull out the laptop to get the BBcodes.
To the pictures:
The nasty input bearing retainer I got from Pull-A-Part. Poor guy didn't know how to charge it, so he just rang it up as "trim". A little over $8, so I wasn't complaining.
PXL_20210131_141905487 by
Terrence Brunson, on Flickr
I got it all cleaned up and installed on the transmission:
PXL_20210131_214200497 by
Manual pedal vs. Auto pedal assembly. The mount holes are all the same except for the 2 for where the clutch master cylinder bolts through the firewall.
PXL_20210201_141607569 by
Chrysler was kind enough to dimple the firewall. The 3 dots in a row are where you drill. It's pretty self explanatory:
PXL_20210201_142007472 by
PXL_20210201_145020832 by
I separated the pedal assembly. To me, it made installation easier.
PXL_20210201_152959111 by
Make sure the pilot bore is clean. I used some rust penetrant and scotchbrite on a drill. I didn't want anything in the 23 year old bore jamming my new pilot bushing from Novak.
PXL_20210201_200132566 by
My flywheel holding tool broke the last time I used it, and 105 ft-lbs is more than I could hold. I just used a piece of plastic coated chain to keep it from scratching the flywheel too much. Worked great!
PXL_20210201_205228514 by
Sheet metal adapter piece pulled:
PXL_20210201_213901946 by
Automatic vs. manual sheet metal adapter pieces. I guess you could use the automatic one if you really wanted to, but I had the manual one available, so I figured why not?
PXL_20210202_150300254 by
Since the old foam piece was destroyed on both plates, I scraped it all off and used a small piece of leftover headliner material to make a foam gasket. I really hate getting cold or hot air in from outside, so I traced it out and cut it, then glued it on with some 3M spray adhesive. Just like you would use on a headliner.
PXL_20210202_154953993 by
PXL_20210202_155055687 by
Here's the proof that the manual (top) crossmember is different. It's about 1/2" or 3/4" lower at the mount. I probably could have cut and welded it, but again... it was available to me, so why not?
PXL_20210202_182202414 by
Here's the transmission making its way home:
PXL_20210202_185321212 by
I really should clean the carpet. I work at a Bridgestone tire factory, so my work boots get covered in black crap. But check out that clean OEM install!
PXL_20210202_205230497 by
And finally, these little ribs the screwdriver is pointing to were hitting the back of the transmission. You can see the tiny dimples on the transmission side, so I ground a little bit of the ribs away. I put a shop rag over the front of the transfer case to keep metal shavings away from the input seal, but I still hit it with a liberal coating of brake cleaner to blast away any residual shavings...
PXL_20210129_201707022 by
PXL_20210129_201715093 by
PXL_20210129_201718899 by
Ground away:
PXL_20210129_202437112 by
