need knock sensor- have one?
88flexj
salinas, ca.
i need a knock sensor for an 88-89 4.0 with an aw4. if anyone has one i could sure use it. while pulling out my motor it got hooked up on the drivers side motor mount and destroyed. it screws into the block above the oil pan on the drivers side. it has a square plug like the one for the fuel injectors. if anyone could help it would be great. i have lots of spare parts for trade also??
I can take a look at my local Pull-n-save when I go on Friday. Advance Auto Parts has them new for $65. While a ton cheaper than dealer, its still pretty steep.
I might. I took apart an 89, and I now don't remember whether I kept the knock sensor or sent it to someone, or for that matter whether it's still sitting in the rusting block behind the barn. I'll try to check tomorrow (tuesday) and post back either way.
that would be great guys. let me know if there is something you could use also.
