Hugothegrunt
- Longmont CO.
Just wanting some input to a CEL code to make sure that I'm heading in the right direction. After buying my '98 XJ 4.0L AW4 I started to have a typical NSS issue, no start in Park, shift to Neutral and it starts. Only happens once in a great while. The Heep has been sitting for about a month and I asked the wife to take it when she went to the store the other day, just to get it running and get everything lubed up. She calls me up and tells me the CEL came on, I asked her if it was running fine or was there any problems that she noticed? She said it was running fine. I took it to Advance Auto today and had them pull the code(s) and they came up with P0700 (Trans Control System Malfunction) and P0705 (Trans Range Sensor). So like a good Noob I hit the search function and came up with several others that have had these same codes and the recommended repair was to clean or replace the NSS. Next time I get the chance I'll clean it. What none of the other threads mentioned was how the repair turned out, the threads ended with "I'll give that a try" or something similar, and what else would cause these codes? What if cleaning the NSS does not fix it? where do I go from there?:dunno:
Whats your thoughts?
