fdsa487
- El Cajon, a.k.a. The Box
[FONT=arial, sans-serif]3 TON SUPER HEAVY DUTY FLOOR JACK
[/FONT]
[FONT=arial, sans-serif]Professionally designed with thick welded steel plate construction and an oversized saddle. This industrial quality unit will quickly become a must for day-in day-out use. Overall dimensions: 26"L x 13-1/2W". [FONT=arial, sans-serif]
ITEM 34271-7VGA
$59.99
AND there is another for the same price the only difference I see is that it does not raise up quite 20", but its discounted from $69.99 to $59.99 so its the same price as the above. I think I like the 1st one more looks like it has a bigger lifting platform. Does Harbor Freight have in stock (El Cajon Store) the same product that they have online?
[FONT=arial, sans-serif]3 TON HYDRAULIC FLOOR JACK[/FONT]
[FONT=arial, sans-serif]Heavy duty construction for daily shop use.
[FONT=arial, sans-serif]ITEM 54877-1VGA[/FONT][FONT=arial, sans-serif]
$69.99 $59.99
[/FONT][/FONT][/FONT]
- Design: floor jack
- Capacity: 3 ton
- Maximum Height: 20"
- Minimum Height: 5-3/4"
- Weight: 94 lbs. shipping weight
ITEM 34271-7VGA
$59.99
- Rugged steel wheels move easily on garage floors
- 39" long handle
- Maximum lift: 19-3/8"
- Minimum height: 4-1/2"
- Durable enamel finish
- 6000 lb. capacity
$69.99 $59.99
