Talyn
- Radford, Communistwealth of Virginia
I've been working on this 94 3.4L Camaro not producing spark. It won't even produce spark to make it start. If you aren't familiar with the ignition system I'll fill you in as to what it needed to at least produce spark to make it start. It has a 7x crank sensor, ignition module, wires, plugs and coils. The ignition module can create spark on its own even when unplugged from the PCM if it has a 12 volt supply and the crank sensor input. It produces a spark until the PCM tells the ICM that the PCM is taking over. Unplug the PCM and it runs on a built in spark map, mainly used for starting.
It came in with a no start issue which I traced to no spark. The coils resistance checked good. I don't believe the coils to be an issue and the ICM isn't supplying voltage to the coils as well. The ICM also isn't supplying the PCM with an RPM signal. The symptom is very intermittent spark. When it does spark the tach moves. When no spark, no movement.
The crank sensor (the 7x/3x sensor, not the 14x) has a suspect looking connector which had been butt connected prior. I replaced that with a new plug, soldered and heat shrinked. I checked the resistance of the sensor and it is in spec. I also checked the wires and nothing was found wrong with them. I also used a multimeter to check for ac voltage while cranking and that checked out as well. I wasn't satisfied with that so today I put the sensor plug to the ICM on an oscilloscope and the wave form is what it should be (if interested I can post that). So that input to the ICM checks out.
The 12 volt to the ICM also checks out. Same diagnostics as I used on the crank sensor. DMM, wire check and scope. It checks out fine with constant voltage.
So that leaves the ICM. I replaced the ICM with a used one. Same thing. I then got a new one and it seemed to work better but the the sparks were still not 100% constant. There was more spark, but it still took a break. This was verified through a spark tester on the coils as well as removing the coils and using a DMM to watch for voltage. Now, after I replaced the ICM the spark became more consistent but still had a hiccup. However, now its more inconsistent requiring more cranking than seeing spark or voltage to the coils.
I also checked the female on the sockets and they are nice and tight on the ICM pins.
Any ideas?
Any ideas?
