NEED $2K IN PARTS OR WHOLE BUILT 95 CHEROKEE
Had a few questions.....what type/brand of lift is on it.....and is it setup with stock control arms...or adjustables....long or short control arms. Also was wondering about the driveshafts....stock...or aftermarket?
Thanks
brand new 6.5" rustys rear springs, sitting at about 8", newer 6.5" rustys coils, rustys shackles, homemade longarms (radius) out of 1 1/2 .25" wall DOM with tractor heims (i know i should have used better, but it was cheap and a trail only rig) driveshafts are stock, rear shocks are bds, front shocks i have a few diff sets, all of which could be a bit longer
o yeah and the trackbar and track bar bracket are home made from 1 5/16" wall DOM and solid bar stock with poly bushings, as well as the factory bracket modify to act like rock krawlers extreme bracket
bump, anyone want to buy the axles...? the d30 has 4.56's, brand new warn manual lockouts, hd lower control arm brackets, and brand new brakes, the 44 is the al hd and it is lincoln locked with 4.56's hd custom made truss / skid yukon shafts and disc brakes. somebodys gotta want these.
