Narrowed 62"wms Full Float Rear Dana 60, 8 lug
Rob Patterson
Colorado Springs
I'm looking to sell my rear Ford FF Dana 60 set up for 4 link and coil overs.
I got this axle as part of a package deal. I don't need to sell it; but if I use it I will be cutting off the 4 link brackets and using it in a leaf spring set up on a Durango. If I sell the whole package, I may go bigger.
Approximately 62" WMS (I don't have rotors so I don't know what side of hub they bolt on.)
4 link and coilover mounts
Spindles are large enough for 35 spline shafts.
Set up for xj or tj or anything else that you want to 4 link the rear axle.
Stock 3 series open carrier, 3.55 gears, spline count unknown (junk parts)
New in Box Parts
Ballistic Fab disc brake brackets
Ballistic Fab welded cover
Nitro 4.88 gears
Nitro install kit
35 spline detroit locker
35 spline Nitro cut to fit shafts
Brake parts needed: '73 - '87 3/4 ton 4x4 front calipers (RC4072 & RC4071) and rotors (5014R)
Assembly required.
Listed on craigslist, I will give a price break for NAXJA members.
$650 for housing and disc brake brackets only.
$2200 for everything, will not separate parts.
Thanks,
Rob
Call or Text: Seven-1-nine, 9-six-four-3-zero-nine-1
OK, I got my wider Dana 60 axle.
I'm now selling the 62" WMS housing, hubs, 35 spline NIB Nitro 4340 axle shafts, Ballistic Fab Disc Brake Brackets. Includes stock cover, carrier (not 35 spline) and gears.
$700 for NAXJA members.
**NIB gears, locker, heavy duty cover, install kit not included**
