Yellow XJNJ
- Trenton, NJ
When my tranny crossmember snapped off 2 weeks ago, I hadnt realized that a bolt got stuck inside the frame rail. Well, I got all my new parts (new crossmember, bolts, bushings) So I borrowed some tools from work and came on home to work on the XJ. Well, I started drilling into the bolt..nothing. Tried 3 different drill bits. Dad went out and bought me a BRAND NEW set of bits and easy-outs. Well, the first attempt put a clean hole right through the bolt. So then I worked the Easy-out in...negative. So I drilled a little more, snapped the drill bit. I ended up losing 4 drill bits to this damn bolt in a matter of 10 min. Well, after working on this bolt a little bit more, I tried the easy out again. Well, as the drill bits set an example, the easy out snapped in half inside the bolt. Now im kinda up the creek here and my paddle got stolen by the natives.
I dont know what the hell to do. If I didnt like my hair so much, Id be pulling it out. I need a beer.
