SeeingSpots
- Bend, OR
There are two issues that I will have to address. One is visible in this pic (minor crack in the filler that I applied). There's another spot at the opposite end of the tank. Both areas don't have much filler in them. He said it wasn't like that when it left his place so maybe it was just temp changes? I'm sure I did something wrong so he gave me some instructions last night and I'll start on that in probably a fews weeks.
That, my friend, is more than likely a shrinkage crack due to low humidity and/or too much hardener in the filler when it was being mixed. Looking at the color of it, did you use retail Bondo? Depending on how deep the crack is, you might be able to get away with putting some quality glazing putty (Everlast) on with a razor blade and then lightly knocking it down with 600gr paper.
Just out of curiosity, did you do any sort of a tank sealer treatment on the inside? POR15 makes a good kit. In-fact, I may have some left over from when I did my old tank. You can just have it.
