1990XJ4x4
NAXJA Member #1158
- Louisville, KY
This thing is gettin quite frustrating. Just the other day i went over the cooling system on it ( replaced heater core, thermostat, flushed whole system, refilled with 50/50 antifreeze and water). It ran great for about 4 days then as I was in an icy parking lot spinning happily it started overheating, ran up to about 235 and stayed there. I stopped and put it in neutral and let it idle ( BTW the electric fan was on the entire time) and the temp didnt go down. After parking at home i can smell antifreeze and hear a hissing sound coming from the bottom left corner of the radiator (looking at it from the front), check the drain plug, its dry but there is a very small amount of moisture on the bottom of the radiator. Could this small leak be enough for it to heat up like that. This sucks since I am low on money.
I have a 1990 XJ, 4.0, AW4
