After a great day of fun playin' in the mud, my jeep started running like crap on the drive home. It would stumble on acceleration, take forever to start up, and occasionally drop it's idle to 300 rpm's. Instead of throwing parts at it I actually took some time to diagnose the problem. Turned out to be the fuel pump. I thought I was going to have to buy a new one, but was amazed at what I found when I pulled the pump. The positive lead to the pump was not attached, it was merely resting against the contact. Also, the clamp for the hose was not tightened, and was resting loose around the base. The hose itself was not even close to a snug fit on the nipple. It seems the last time the pump was replaced the moron who owned the jeep did a half-assed job putting it back together. They didn't even get the gasket ring on well enough to keep the fuel from dripping when the tank was full. So when I went to play in the mud, I bounced the tank off the ground, and the pump stopped working. Now I have everything cleaned out, the pump is back in, and the JEEP DRIVES BEAUTIFULLY! I can't explain how good that feels after weeks of frustration trying to figure it out, and now I can drive again. So.....Anybody else have a fun story about a simple problem, that ends up being a PAIN to fix/diagnose? OR bought a jeep, and then later found out that the seller did something incredibly hair-brained to the poor thing? STORIES! I know there's some good ones, let's hear 'em!
THIS is my jeep. It's bone-stock, but still a lot of fun!!
