She runs!!!!!!
We got the long block assembled and in last weekend. Everything went in okay, no hiccups. Had to drain the gas tank (bad gas) and get some spare fuel injectors since the original injectors were clogged.
When we went to prime the motor we discovered we had low oil pressure. Pulled off the valve cover and looked over the valvetrain, no problems other than lifters in cylinder 1 and 2 weren't pumping. Scratched our heads for a bit then realized we hadn't plugged the oil galley behind the cam gear. Doh!
Finally went to start it and the motor would just crank. Double checked the indexing on the distributor and it was a little off. Adjusted it... she started right away! The motor sounds great! We idled it for about 20min and did a walk around to make sure things were okay.
I took it for a quick spin. First impressions... The Centerforce clutch engages very sharp with not a lot of give. Almost killed it backing out of the garage lol. This thing is a blast to drive. Between the 4.10s, stroker, and a manual it was such a breath of fresh air over a 4.0 3.55 auto. Plenty of power...PLENTY! I got used to the clutch engagement fairly soon and I'm comfortable with it now.
The suspension rides stiff and solid
. I didn't bother flexing it out or anything since I was too anxious over the motor. Sounded like the rear brakes were grinding a bit. We set the drums brakes pretty tight so they might need to be adjusted. I'll get pics of the rig up soon.
