01_XJ
- Emporia, KS
I just got home from trying to get this thing smogged but it failed. I've attached a scan of the numbers to this post. The Nox reading at 15mph was the one that did me in. It was supposed to be under 517 and it measured 808. I talked with one of the guys there for a bit and he seemed to think it would be either carbon buildup on the pistons or an issue with the cat. He had recommended getting a bottle of the Guaranteed 2 Pass (which I did on the way home and already have it and a bottle of Heet in the tank).
I replaced the 0331 head back in August with a brand new casting because it had cracked, and while it was off I cleaned off the pistons pretty well. Would the O2 sensors have any effect on the Nox values? I had to replace one a few weeks backa nd have had my CEL come on and off a couple times since. When I hit it with the OBDII reader a few days ago it was showing i think 4 codes and they all had to do with the other 3 o2 sensors in there. Looks like I'm gonna have to replace them all, but I'm wondering if that even effects the Nox measurement.
Other than that, I got the engine warm, have recently changed the oil/filter, plugs were done with the new head, all new cooling system parts. I'm not really sure where to go from here. Do I let this G2P run through the system and try it again, or do I go replacing stuff?
