Re: moving to Germany need advice
Lifts and such have to be approved and documented, at the inspection station. In fact most any mod has to be inspected, documented and entered into the vehicle registration papers. Most of the guys that mod, build sleepers and put the add ons where it doesn't show as much (and take them off before inspection). If your going over in the military, they have there own inspection stations and things are a bit more flexible.
If you are coming over as a civilian, don't lift till you get here, depending on the mood of the inspector, even with the proper documentation, approval can be an iffy thing. You can easily double the price of your lift, if you have to get a dealer or a garage to approve/inspect it and supply the documentation. Pro Comp, Rancho and some others have gone through the trouble of getting blanket approval for there products (but you need the documentation papers, that come with the kit). Some manufactures stuff is installed and approved on a case by case basis. Rubicon Express is getting more popular, but I'm not sure if there stuff has been generally approved or needs an engineer to sign off on each individual installation or not. Point is, it's iffy and often depends on which inspection station your going to and whether they've seen the mod before etc.
Parts aren't really a problem anymore, there are various outlets, though they are expensive. One supplier (
http://www.asp-eberle.de/ ) does next day UPS delivers and uses mostly Crown automotive parts and has a pretty good stock of stuff, right down to complete and individual parts for the transfer etc. The site is also in English, a dollar is about 4/5 of a Euro, so you can get an idea of the prices.
Whenever you get over here, I can supply you with enough outlets, so you have some choice, in selection.
I usually have my daughter put together a care package from the states and keep normal consumables on the shelf in the garage, you can save a bunch that way.
If your coming over as a civilian, the import duties, the required headlight change and other stuff to meet the Euro standards and the documentation to pass inspection are a whole other can of worms.
Whomever ships your XJ can help you out with that. If a private company is sending you over, along with vehicle shipping, get them to spring for the Euro changeover also, which can add up to $600 (or double that) or more. Which can also be arranged through the shipper, usually.
Military are allowed to run with USA spec vehicles. State department and others aren't and have to change over to Euro standard lighting etc.
The whole thing will make you dizzy and changes often.
