PlainWhiteXJ
- Northern New Mexico
Cottontail said:Another problem with the hitch mount tire carrier...
That carrier will not fit snuggly into the hitch, and everytime your truck shifts, or you hit a bump, that carrier is going to move. I can only imagine the noise that it will make driving down the highway with the metal hitch rubbing and hitting the metal carrier, especially with a heavy tire mounted to it!
It may not be really loud, but it will be constant, and I, for one, couldn't live with that.
Tried to mount a 32/11.50-15 on the back of a 73 Blazer with a popup camper this way (stuck in the reciever hitch)- the tube rattles bad and the sway of a heavy tire is at least 1/2" side to side. Tried to bolt the spare mount to the reciever frame with two 3/8" bolts - less rattle but still big sway. Used 2 x 2 x 1/4 A500 steel tube with gussets at joints. Mount weighed maybe 35 #. Ratchet strap to tension fixed most sway, but big, hinged, purpose built carrier sounds better. Never tried one to be sure.
