New to jeeps,but not to mechanics.I got a 90' ,4.0 ,aw4 ,4wd bone stock.159,000 and still strong lotsa torque for a 6 banger.
Picked it up for 500.00,bad blow by,oil leaks,all fluids needed changed,tps was bad owner thought tranny was gone,about 400.00 later I'm ready to drive this thing almost.
My problem is a metallic noise like a bearing on an alternator or something.The last work was rear main seal,oil pump and pick up tube(coated with sludge) cleaned pan out,and while down there timing chain had lots of slack changed that too.Noise was not there before I changed these parts so I suspect one of these,did all 3 before reassembling and running.I have run motor w/belt off noise still there.noise seems to be in front of motor.I went back in and checked rear main torque,not much to screw up here.Rechecked oil pump,primed w/tube in oil pan straight bolt up.Timing chain oil slinger flared lip facing out ?,cam sprocket torqued w/spring and pin installed(not sure what the purpose of this is for).
Any ideas ? what am I missing here,It runs good but something sound like it is rubbing or a metallic bearing noise.
