motor dies???
bluebeast
Nor Cal
I will be driving at low rpm usually just starting out, going up a hill doesnt matter how steep and the motor cuts out. It's like the fuel pump cuts out or I loose spark, but just for a second. It's really bothering me. Could it be the crank position sensor? Fuel pump, coil?
When you say "low rpm" do you thing it happens at one point on the accerator peddel?
Sounds like a dead spot in your TPS, cleaning may fix if so.
