More Stuff for sale
Ben H
Fresno
Ok guys, round two of me selling jeep parts. I’m going a different route and will not continue to build on my XJ. I’m kinda bummed about the work and metal I’ve already added to her, but I came across a deal that I just could not pass up. The prices on most of this stuff are pretty low as it is and is priced to sell quickly. Of course, if you is a homie, you qualify for the homie hookup. The smaller stuff can ship if you pay for the shipping. The larger stuff will need to be picked up or can be delivered.
I will reply only to PMs. Please keep posting in this thread to a minimum... it will help keep it organized
Here is what I have for sale, details of items are found below:
Used Tires & Beadlocks-$1,000
Used Front Dana TJ 44-$1,500
Used Rear Dana TJ 44-$1,000
New Clayton 3 Link-$400
New Clayton Front Axle Bracket Kit-$300
New Dirt Bound 3 electric Fan System-$175
Used Farmboy Design Rear Bumper-$200
New Race Trim Seats, with XJ brackets-$250
New Rear XJ Coverking Cordova Seat Cover Black-$50
New Full PSC Hydro Assist for XJ -$750
Used Warn 5x5.5 Hub Conversion -$900
New Hesco Injectors 24lb for 2000 xj-$75
Used Big Off-road Leaf Springs 6.5" HD-$300
Used Rubicon Express 4.5" leafs-$150
New New Grant Steering Wheel-$75
Used XJ Doors (4door late model)- $50 per
Used 4.5 x 5 wheel spacers -$50 pair
Used 4.5 x 5 to 5 x 5.5 spacers-$50 pair
New HD Off-road Stubby with Wings-$200
New Brand New Optima Yellow 54g-$175
New 12" ORI struts pair-$1,100
New Energy Suspension Tranny Mount New-$50
Used Bilstein 7100 12" Short body -$100
Used Yukon Super Joints- $150
New TNT Customs Ubolt Eliminators-$100
Used Metal Tail light housings-$75
New Mean Green Starter-$200
New 5-90 Battery Cables-$75
Used Rocktrack 4:1 Tcase-$800
Set of 4-35”x12.5x15 Maxxis Creepy Crawlers on steel Allied Beadlocks. A lot of good tread life left in these, typical rock rash on the beadlocks. A little flat spot on these bias ply tires. One of the wheels leaks due to the rim being slightly bent. Nothing a little heat and a hammer can’t fix on these steel wheels...hence the awesome price.
http://www.maxxis.com/AutomobileLigh...-Off-Road.aspx
http://www.racelinewheels.com/p-811-...k-8-steel.aspx
Clayton Offroad 3-Link Kit, less the two parts of the cross member that are welded on already. This is a brand new 3 link kit that I welded up and never ran. All Johnny Joints are brand new. I also have a complete Clayton Offroad front axle bracket kit.
http://claytonoffroad.com/product_in...roducts_id/311
http://claytonoffroad.com/product_in...products_id/83
A brand new pair of Race Trim Seats, wide highback seats. All black fabric, vinyl siding, with late model XJ seat brackets fabbed to be a direct bolt in. Have a matching rear seatcover that is also sharp black.
http://www.jbugs.com/category/RaceTrim2.html
http://www.coverking.com/
Front and Rear TJ Rubicon Dana 44s with 5.13s. I just bought these off a guy who built them, used them for a few runs, and then got deployed. The price I paid is the price I’m asking.
The front 44 has CTM’s, Alloy inners, Alloy BIG 30 spline outer with big unit bearings. Both wheels turn with the stock Rubi Air Locker powered by two stock Rubicon air pumps. Comes with spare inner chromolly shafts. This axle is trussed, set up for coilovers and has brackets for the above Clayton 3-link welded on. The passenger side knuckle is a TeraFlex Knuckle set up for highsteer. The LCA mounts have skid plates. The inner C’s are trussed and hold onto the new Moog balljoints.. The diff is protected with a G2 Diff Cover and the inner shafts have the Alloy outer seals. This axle comes with ¼” tie rod with mounts for hydraulic assist and offset track bar mount. The custom track bar and draglink are included with the axle. I have a frame side track bar mount ready to be welded onto you junk.
The rear Dana 44 has chromolly shafts that tie into the 35 spline ARB locker. The pinion has a 1350 yoke, with yoke skid plate. This axle also has a bridge that was used for a four link in its prior life. The rear has disc brakes.
The Farmboy Design rear bumper is badass. It is a custom built tube bumper with wrap around quarter guards. Has taken a beating and is shows, but it is a good bumper with a built in hitch and over 20 mounting points.
The front ORS off-road bumper is one of the first prototypes Chris (Action Fab) sent out, just before he went public with them. Very nice, with recessed hidden winch and wings. I welded this thing to my frame plating and will need to plasma it off, hence the price.
http://www.naxja.org/forum/showthread.php?t=1071333
The Warn 5x5.5 hub conversion has suited me well over the years. This makes the weakest link in your front axle the easily replaceable, lifetime warrantee hubs. This comes with a spare set of hubs for the trail, outer 30 spline (same as a Dana 60) shafts, with a spare. The price includes a new set of Stage 8 Spindle locking nuts ($120 value).
This kit is now made by Yukon I am told
Brand new set of TNT Customs U bolt eliminator kit. Used for mock up only, never tacked on. http://www.tntcustoms.com/u-bolteliminiators.aspx
The 12” travel ORIs are brand new and speak for themselves. http://www.naxja.org/forum/showthread.php?t=1071333
One of the Bilstein 7100s is blown out in the bottom and needs repair, but is rebuild able, hence the price. http://www.polyperformance.com/shop/...k-p-19267.html
The Rocktrac transfer case is on the rig that is being shipped to me now. My atlas/klune combo will replace it. It would be nice if this could cover the cost of shipping my new rig to me. I think these go for around $1,000 used, so I think I’m price competitively. This one reportedly has 39,000 miles on it and works.
The PSC hydro assist includes a used single sided ram, a brand new tapped PSC box, brand new steering pump and one of those bling aluminum reservoirs and all lines. The ram had only few runs prior. http://www.pscmotorsports.com/95-02-...ssist-kit.html
The mean green start is brand new and titties.
http://www.mean-green.com/
Most of these parts are pulled and are ready to ship or to be delivered. For those interested, the jeep still has a strong 4.0 and AW4. It can be picked at if you want to do so in the evenings, but a wrecker will come and get this sucker at the end of next week.
If you are interested in something I’ve posted shoot me a PM. I’m not in a huge rush to sell this stuff as I can get most of it in my storage shed for now. Pics will get posted up shortly of most of this stuff.
Happy Turkey Day
Wow everyone, thanks for all the interest. I'm still a little turkey drunk from last night. When I get back home late this evening I will respond to PMs and definitely post pictures up. I just reread my post above and i must apologize about making that so difficult to read through (sad especially because I write to live).
:cheers:
Photobucket wont let me access anything other than a "mobile" website. Dont know whats going on with that. I'm going to try to post from my office tomorrow.
Ben,
How many miles on the 4.0L? Is it out of the Jeep?
Thanks,
Tom
Hey Tom, I recall seeing over 130,ooo on the clock. Still in the jeep. If you are looking for a new head, I have a spare head that Bryan C hooked me up with several years ago, when I was worried about the cracked 0331 head issue. Never used it and it is Chyrsler's fix for the cracked head issue...Direct replacements for the 0331 head and no longer prone to cracking. Sucker has been in storage for a while as my head never cracked.
Ben,
Mary's 01XJ w/155K loses oil presuure at idle, thinking cam bearings and I would rather just swap an engine than rebuild.
Tom
Tom,
I've got a local guy coming by this Sunday or Monday to pick up the shell and what is left of the drivetrain. I probably wouldn't swap a 150,000 for a 130,000 mile engine anyways. Good luck fixing Mary's jeep.
I have a box of stuff that whoever comes down ASAP can go through and have free picks. Said box has a spare sensor for the entire jeep, spare ball joints (new), spare stock shafts, drivelines, loaded full of spare stuff for the trail.
Here is how she sits now:
Steering Reservoir (New, only bolted up.)
New Steering PSC Pump (New, only bolted up.)
PSC Gear Box, with Assist Ports (New, only bolted up.) If you want that pitman arm its $150
Maxxis Crawlers and Allieds
Front TJ 44
Rear 44
Dana 44 Steering and Trackbar
RaceTrim Seats, new, with seat brackets for direct bolt in
Klune V $1,250
Atlas 4.3, $1,800
Warn 5x5.5 Hub Conversion, with spare shafts, and a spare trail hub
Tail Light Housings
Rear Bumper
XJ Doors, Big Offorad Leafs, Trackbar
XJ Front Bumper, bent bracket $100
BNIB Small ARB Pump, with lines, extra filters and fittings $150
ORI’s
Dana 60/70/ 14 bolt disc brake mounts, and rotors $50
Mean Green Starter
Willwood Proportioning Valve, ARB Stainless Line, 4” rear bumps, wiper linkage, speed bleeders
Couple of Hawse Fairleads, $30 a piece
New Optima
Alex E will be coming down from the Bay Area next weekend to get some stuff. If you want any of my junk, now would be a good time to get it so he can bring it back for you.
Thanks Again Alex!!!
Also forgot about the RadDesigns Rock Shifter and AW4 controller. Whatever his price is, they are new. Forgot what I paid for them and dont need it with the Rubi tranny.
Here is what is gone or spoken for:
Jeep and all body parts
Front Bumper
Rear Bumper
Shocks
Battery
Thor Cold Air
Front 44
All suspension parts, less the clayton long arms
ORIs
Rocktrack 4:1
These are also gone or have been spoken for at this point:
Dirtbound Fan Setup
Tail Light Housings
I'm going to hold onto the Klune and Atlas until I am certain they will/wont work for me.
Solid interest in both the Dana 44's
