did a s10 bastard pack,wanted 3 to 4 lift but got 7.i like it but drive shaft angle is real bad,like 35 degree angle.if i put 8 degree shimms in would it fix it.
An XJ/S-10 bastard pack will give about 4 inches of lift with this recipe: XJ main/S-10 main/S-10 2nd/XJ 3-4-5. Whatever recipe you use, ditch the flat S-10 overload leaf on the bottom.
You will need an SYE, and to measure for the correct SYE shims.
