- NC Sandhills
OK, first off assume I know very little, but enough to be real dangerous. Especially inside the "disk management" utility :laugh2:
Background info: I built a ground up Windows desktop PC, (XP Pro SP3) over the weekend...
Basic stats: Pentium core 2 duo E5200 2.5GHz, EVGA 610i mobo 4GB DDR, Graphics card w 1GB, dual internal 320GB 7200rpm WD Caviar SATA drives, dual internal SATA HP DVDRW drives, 400w PS... Nothing exotic by today's standards, but by far the best one I've ever had.
My goal is to have both internal HDDs in RAID 1 (mirror). The steps to get there aren't exactly clear, so if someone in the know can steer me...
Drive #1: I got XP, hardware drivers AV, ISP & a few games loaded up, surfed the web, played a few missions, everything seemed great!! Trouble is I set a huge partition 270GB NTFS where this stuff resides.
Drive #2: I set up a 30GB NTFS partition last night: Loaded the same as #1 -OS, drivers, AV, games on the small partition, then set another 268GB NTFS partition that is currently empty(just a -100MB shell).
I'm going to say that my efforts have been good practice drills, (and I have created two stand-alone drives that run XP & games well) but I bet that it's all needing erased and start over.
I guess step 1 is getting into the CMOS and setting boot drive heirarchy?
Assume priorities here 1--> DVD#1, 2--> DVD#2, 3-->HD#1, 4 --> HD#2, 5 --> Floppy. I don't have a 3.5 floppy installed, but there is one showing up in there as boot #1 ...might be seeing an empty USB/SD card slot? Or just a built-in default to the MOBO?
Then I guess we need to get into the BIOS and set it up to RAID 1 mode? (I burnt a CD with the RAID driver from the MOBO driver CD, and the MOBO will support mode 0 or 1)
When reformatting the drives... will I have to reformat each one independantly? (if one at a time, then set identical sized NTFS partitions?)
I read that in RAID, both drives need to have the same volume? (H: ) & (I: ) in my case... OR will enabling the RAID mode automatically do the same actions to the drives together?
How big, and in what format should I make the partitions??? (My old PC with a 40GB HD has like 5GB in FAT32, and the rest in NTFS)
Drive volume assignment: I grew up with the old (A: = big floppy, (B: = small floppy, (C: ) = HDD etc... then we got high-falutin CDs and (D: ) or (E: ) was the optical drive. On this new POS, C-D-E-F are the card reader slots, (G: ) is the DVDRW #1, and the first volume HD was (H: ) and the second partition became (I: ) DVD #2 is going in this evening... dunno what letter it'll assign to it yet...
Assuming both HDs were empty... I doubt would it hurt anything to reassign the volume names? OK then... assuming my (H: ) drive has 20gb of system shtuff, program files, drivers etc... would renaming it (X: for example) cause all the drive path stuff in there to change from (H: ) to (X: ) with the rename? Or would renaming an existing drive foul up all sorts of things? :laugh2:
Oh yeah! Wildcard: I have a 1TB external drive, which will be for off-system backups. It is currently set as one huge FAT32 volume... It has aprx 20GB of pix & docs on it from the old PC (no biggie to backup to DVD-R in other words) Before I feed anymore slop to this one, should I reformat it to all NTFS? If it needs a partition, how big?
I guess that's enough questions for now... :eyes: before my head explodes! As you can probaby tell, I am lost in the woods, big-time. Learning curve = cliff scaling at Pont du Hoc.
Thanks for any good advice...
