- Torrance, CA
It's been eight or ten years since there were several on the forum who were experimenting with using resistors to fool their OBDII computer.
I too was trying to discover a solution, originally only finding the pre-97 method.
http://www.go.jeep-xj.info/HowtoAutoSwitch.htm
I don't remember anyone actually getting it to be foolproof and publishing the plans.
Search is failing to find it.
Do you have more information on this?
http://www.naxja.org/forum/showthread.php?t=1103022
A 1k ohm 1 watt resistor from each solenoid output on the TCU to ground seems to go the trick. :wave:
