Also some spec on the steering...
I was planning on posting them up once I got it all fined tuned. Had to cut one back down an 1" to allow for adjustments. Carpentry skills in play there, they were measured to a tight fit.
Tie rod is - 43 1/4" (tube end to tube end)
Draglink- 33 1/2" (tube end to tube end)
I ran a LH thread on the end of the stock on the left side of jeep and RH thread joints on the right hand side. This is what allow you to adjust your steering, then use lock nuts to secure them in place.
As far as the track bar I'm thinking of running a double ended heim joint stright bar over the axle. Was thinking a bushing on the axle and joint at the frame. but using the same size stock being 1 1/2" x .25 wall and get tube ends to insert then my joints.
