MJ springs in an XJ???
soulslngr
Northern NJ
is it possible to use MJ spring to lift an XJ? considering that the MJs are spring under would swapping them onto an XJ pack lift it? I was just looking at some MJ pics and had te brain storm, but couldnt remember if anyone had ever mentioned it.
thanks!
They are about 4 -5 inches longer than an XJ pack.
Goatman moved his front spring perch to accomadate the swap.
CRASH
when we did my brothers, we cut the eyes off the mj main leaf and ran the entire pack under the xj main leaf. with the mj shackle it sits perfectly level with the 4.5" coils.
matthew
The stock MJ spring is 5" longer than the XJ's.....3" longer in front and 2" longer in back. I moved the front spring hanger forward 3" and made a boomerang shackle for the rear. I didn't use the whole MJ leaf pack, only the main leaf, so I can't tell you how much lift you would get.
