Jeff 98XJ WI
- Butternut, WI
Well, I'm following this build closely too.
Looks great! I've got a few questions if you don't mind. First, what mounts are you using for the motor? they look like purchased mounts and not custom. Are you happy with them and do you think they'll work well? How about the frame reinforcements? It looks like you either plated the side of the frame with plate steel or used a piece of box steel with the top and bottom cutoff except for the front portion. The plate is plug welded and welded along the edges, right? How about the bottom portion of the frame? The frame kind of changes width, but your plate doesn't. Is the top portion of the frame plated with a piece of steel cut to match the shape of the flat top portion and then welded on? Are you going to weld anything on the inner portion of the frame and/or the bottom? Again, it looks great. I've got an '88 MJ with a clean body sitting along the house with no drivetrain or engine harness just waiting for me to do what you are doing!
Jeff
