MJ for sale
muddshutter
Jeep Comanche 87/97
Virginia Inspection
Less than 300 miles on everything
Since everything is new or has been replaced
Truck was originally purchased for $2000
Was featured on a popular website before purchasing.
http://www.4x4wire.com/jeep/projects/comanche/
Then Came the transformation:
Short bed, bed liner, interior has truck bed coating under the carpet, TJ floor plugs, new headliner, new sun visors, front skid pan as well.
7.5 inches of lift overall
4.6 Liter Titan Stroker Engine $1950
24 lb injectors & Champion plugs
Flowkooler water pump $100
3 core radiator CSF $200
twin electric fans 5k total air flow $200
Poly Tranny mount $45
Rusty’s air intake
K&N cone filter
Firepower ignition system $175
All new sensors, hoses, belts, plugs, etc $600
New valve cover and oil pan, upgraded oil filter
Centerforce clutch $299
M.O.R.E. bombproof rubber engine mounts $130
M.O.R.E. bombproof Block Brackets $240
AC lines removed
Ax-15 external slave, Rebuilt Professionally and
shifts smooth, new shifter knob $600
New Starter $35
New alternator $75
NP 231 Completely rebuilt with SYE & Novak conversion $400
Tom Woods Front & Rear driveshafts $400
Pacesetter exhaust header $200
Flowmaster custom made exhaust with New Cat $250
5 - 35” x 12.50 x 15 BFG Mud Terrain tires $900
5 – Pro Comp Black steel rims with chrome centers $175
Rock Rats black lugs $20
97 XJ front grille, fenders, silver star lights, and mirrors $400
ARB bull bar front bumper with aluminum fairlead
Mile Marker 8000 pound Winch $400
Synthetic line 3/8” x 150’
Custom made rear bumper with 2" receiver mount
New glass: $300
The windshield is brand new with a light tint, New regulators on both door windows, new rear glass with slider and lock, new rear view mirror
Dana LP 44 rear axle: $1200
ARB air locker, professionally installed with Alloy USA 4:88 gears & 30 spline USA Alloy shafts, new bearings and seals. All outer axle connections have been welded. Tera-flex rear disc brake conversion, new brake pads and rotors with braided brake line and proportioning valve.
Dana HP 30 Front Axle: $1100
ARB air locker, professionally installed with Alloy USA 4:88 gears & 30 spline USA Alloy shafts, new bearings and seals. All outer axle connections have been welded. New brake pads and rotors as well as braided brake lines.
JCR 1 ton steering upgrade, professionally installed. $400
JCR Stage 2 Rock Sliders $250
TNT steering box reinforcement $150
TNT Customs Y link long arm system and Adjustable Trac Bar $1300
Uni-body frame stiffeners/frame skids $250
3 Rear frame stiffeners. These support the gas tank & E-brake, allowing the bed to be removed without taking the tank out first. $100
ACOS front spring adjustable spacers $200
6.5 inches lift front springs $110
JKS bar pin eliminator set for front shocks top & bottom $150
4 - 10” 5150 Bilstein shocks with remote resivour $400
Alcan rear leaf springs, custom made $400
Rock Krawler boomerang 1.5” - 2.5” $100
Gel cell battery
Free Motorola handheld CB new in the box
I am moving for a new job and i cannot take this with me. I want to, but i really cannot. The Jeep is almost done. The winch needs to be hooked up but is already in the bumper. The truck needs to be primed and painted. I have MANY extras that i will throw into the sale, for free. I have left out many little things that are brand new and certainly come along.
I have 12,500 newly put into it and totaling around 14 in all. I did not build it to sell, i really built it for me to use for the next ten years. But things change very fast sometimes. I'd like to fetch $9500 or so from it. Someone will get a SUPER deal and there is a bunch of extras that will come along as well.
I want this thing SOOO bad, but I don't have the moola. Congrats on the build though. If you wanna trade on a 99 XJ with a blown up engine lemme know :)
