i got a smokin deal here are the specs...
Front Chevy dana 44 out of 78 chevy truck
Lockrite, 5.38's gears, Bob roggy crossovers steering arm (reemed for large chevy tie rod) new brakes, new superwinch lockouts, newer bearings all around. This axle comes with a spare housing and spare shafts.
and a
Chevy 12 bolt rear out of 78 truck (I know it isn't the best, but should hold up to my driving, not real heavy on the throttle)
5.38's, welded spider gears, blue torch diff cover, blue torch torque bar brakets welded on, new brake lines, new bearings, This axle also comes with an entire spare axle, not sure on ratio, but good for spares.
Then I have to find a d-300. 5.38's are pretty darn low, so I will probably run 35's or 37's
