Missing fan shroud ?
4byfour
Shelbyville, Ky
Can some one please advise if a 2000 cherokee sport IL6 should have a shroud over/around the clutch fan....Mine does not, if it's supposed to be there, will 90's model bolt up? I have a PULL A PART near but all they have are 90-98 on the lot.:confused:
Not 100% sure but I believe it should have a shroud on it to help direct the airflow. I don't think the pre 96 model will bolt in place but if you get a 97+ it would probably fit.
1987-2001 4.0s will work, they're all very, very similar.
Yah I thought they were the same but with so many other things changing from 96/97 wasn't sure if that was one or not.
haha i just checked with multiple different dealers from around here. They are wanting around $50!!! It's outrageous.
