chris_conant
- New Jersey
Might have to sell my jeep. Was just wondering what you guys think it may be worth. Thanks. If anyone may want it I am open to offers. If anyone wants some more pics I can send them. I am located in glen gardner NJ 08826
1997 4.0 5spd. About 135,000 miles. Runs great Current odometer says in the 150,xxx but that was because I changed it out so I could have temp oil gauge.
Flow master cat back
Has 4.5 x series rough country lift adjustable upper lower arms, full leaf pack not aal. 2.2 series shocks 1” spacer and shackle.
Rock krawler track bar with bracket
Steering box brace
Rock krawler sway bar discos
Grand Cherokee tie rod
NP 231 Advanced adapters SYE. Done 2 years ago royal purple fluid
Toms woods customer rear shaft
Hp D30 4.56 motive gears and master install kit done couple months ago.
27 spline 4340 Yukon chrome-moly axles. (spare stock shafts)
Alloy usa axle seals
Loc-rite locker
Ruffstuff diff cover lube locker gasket. Royal purple gear oil
8.25 29 spline 4.56 motive gears and master install kit done same time (spare shafts)
open no locker
ruffstuff diff cover lubelocker gasket. Royal purple gear oil
ruffstuff u bolts and spring plates
Logans metal works front and rear bumpers
Ramsey 8.5e winch
32 11.5 15 goodyear mtrs with Kevlar, great shape not rock rash maybe 5000 miles
4 bfg 32 11.5 15 Mt’s one mounted on same rim as on jeep. Still have life left
H4 headlight upgrade with wire harness.
Hella optilux 4” HID driving lights
Cheap backup fog light but upgraded H3 bulbs
pioneer head unit, infinity perfect speakers in front, 2 way not sure what brand in rear, have 4 channel amp in jeep for speakers not hooked up
Rockford Fosgate amp and 10" sub
highlift jack and some various other things as well
Have roof rack idk what brand, not mounting brackets have used ubolts work fine
Home made front tube doors
ViAir 10003 Medium Duty 150 PSI 325C Onboard Air System
Few bad things. Few has scratches most jeep do, dent on rear driver door. Driver side rocker has a large rusted out area. Driver side manual window needs to be fixed to go up and down, I have looked into it just needs bottom bracket I will prob get around to it soon. Rear tailgate shocks gone and tricky to close but does. And as with most jeep the interior roof upholstery hangs down.
Steering box brace
Loc-rite locker
open no locker
Ramsey 8.5e winch
