RustysOffroad
- USA
Our MasterCraft Safety Nomad seats and harness deal.
$500! This is a SCREAMING deal!
Call us today!!!
Don't miss out on this incredible deal! For a limited time, you can buy this special bundle that includes a pair (2) of Mastercraft Nomad seats AND a pair (2) of 5-point safety harnesses! Buy everything you need for your two-seater and save HUGE!
About Nomad Seats:
The new Mastercraft Nomad Seat is a lower-priced alternative to the conventional Mastercraft seats we sell. It features much of the same quality and comfort features you would expect from Mastercraft, but in a lower cost alternative.
After years of development, the MasterCraft Safety Nomad Seat has arrived! The Nomad is a fixed back, import seat based on the legendary Rubicon suspension seat design. Not just another Import seat with the Mastercraft name slapped on it, the Nomad is a true suspension seat that was designed from the ground up and is built to Mastercraft specifications. Nomad seats feature the same tubular steel frame and open mesh liner construction as the legendary Rubicon seats and even share the same mounting configuration, so they will fit anywhere the Rubicon seats do, and use the same mounting kits and brackets for those vehicles that require them. Upholstered with FMVSS rated fabrics means these seats are colorfast to the same standards as the OE manufacturers.
Available in black only.
About Mastercraft Non-Racing Restraints:
All 3in. driver restraints are SFI-16-1 approved. Our hardware is manufactured from sheet alloy steel or drop forged alloy steel, with military spec webbing. Most sanctioning bodies require all belts/systems be re-webbed or replaced two years after the date stamped on the SFI tag. This is done for your safety. Available webbing colors include: Red, Blue & Black.
Most commonly used for racing applications 5-way latch & link belts
Seat Belt: 3in. wide x 50in. long, pull down adjustment w/ Velcro latch guard cover
Harness: 3in. wide individual, pull down adjustment
Anti-Sub: 2in. wide
Shown with optional Sternum Protector
Restraints can not be returned.
Call us today!!!
About Nomad Seats:
Anti-Sub: 2in. wide
