KRONIK
- CRAWLERADO SPRINGS
damn i know. i have a simple thing to show you. but cant find any pics or video.
i ll try and describe it. let me know if you want more detail.
imagine your fender on the truck.
imagine the wheel opening as you need it, on a piece of plywood.
position it 10 inches out from your wheel.
imagine cloth fastened on the fender body line and draped over the plywood. now adjust all the cloth so all the wrinkles and waves are gone.
glue tack or staple the cloth to the plywood so it stays in position.
now if this were fiberglass cloth once the shape is right, brush or spray gel coat on the fabric and let it cure. add 4 to 5 layers of CSM ( chopped strand mat) and your fenders are made. then sand smooth and finally spray one last time with gel coat. from there sand and prime, no foam, less mess and easy to do.
once done you can screw, rivet or bond the panels to the metal fenders.
use fiberglass cloth in 4x4 twill as it will be super easy to take any 3d shape for the initial shape.
to hold the first cloth to the fender you can screw a strip of wood to the fender clamping the cloth in place. brush or spray on the gel coat.
if we have an old sheet and tape and a piece of wood i could come down and mock one up for you and you can see it in 3 d and better understand what i mean
thanks.
how would I keep the fabric from drooping?
I may need to have you start a fender for me so I can get the idea of what you are saying.
wouldn't the wood create ridges in the fabric and resin? :dunno:
feeling really confused now. Hahaha
