lsx 1T XJ
choogala
Watertwon MN
starting to build my new daily driver XJ. 2000 xj aluminum 5.3 4l65e from monster trans ford dana 60 4340 shafts with 35 spline outers 5.13 gears ARB front with a 14 bolt shaven to the TMR 15 bolt conversion with Yukon grizzly locker on 37"
Are you ordering the 4l65e directly from monster? Or installing 5 pinion planetaries into a 4L60?
I only ask since I have built 2 trans' with the monster in a box kit with the upgraded planets and the way they do their front planet to reaction shaft bearing is wrong. It's known as a failure point that they fail to accept and change.
For your reference: 4l60e correct way to install the 5 pinion planets
Also, sweet build plans. I am finishing up a similar build.
sending armor/flairs, diff cover, motor mounts and brake brackets to powder coating today will have them back tomorrow. going to be cutting out the axle trusses tonight after work
