Lower Control Arms
woody431
Virden, IL
I'm lifting my Jeep about 4", and I already have a set of coils on the way, so I'm in need of a set of fixed LCA's. Brand doesn't really matter, but preferebly RE or Rusty's. If I stay at 4" will fixed arms be ok? I know I'll eventually go a bit bigger, so I'll change to adj uppers and lowers in the future, but are the fixed ones ok for a dd? It doesn't see trails very much right now, but it will. I just want it to flex good and ride good.
So if you have any LCA's, let me know, cosmetic condition isn't really important as, most likely I will be sandblasting them and repainting them. Joints should be in good shape also. E-mail me at [email protected] or leave me a message here, pics would be a huge plus. Thanks
fixed lowers are good for 4" of lift, if you do go higher you can get some adjustable uppers, to go along with the longer lowers.
Are fixed uppers and lowers ok for 4" lift? I found a set of Rusty's arms for $120, so i'm most likely going with those. I'm assuming they are if stock uppers are ok for 4" lift. How will I dial in the suspension with fixed on both ends?
You can fine tune the castor by adding/removing shims in the LCA mount on the frame. There are two 13mm(?) fasteners facing rearward on the mount.
-Brian
