blistovmhz
- Vancouver, BC
The bolt on the lower control arm (axle side) has worn the bolt hole in the bracket int a much larger hole (or oval).
I know I should cut the brackets off and replace them, but I don't have shop space right now and am wondering if I'd be safe to weld the washer to the bracket. The washer is about the same thickness as the bracket and IS the right size for the bolt. I don't need it to hold forever, but the problem is just getting worse every time I drive. Some XXXXer stole the hose fittings off my shocks remote reservoir, spilling oil everywhere, so the oil is lubricating the bolt/bracket and causing it to grind itself down quite nicely.
Will welding the washer hold for a bit till I can get those brackets replaced?
Also, anyone in Vancouver area have a welder? I hate to have to go out and buy one for this one job. I don't have a shop to store it in, so I'd end up with a welder in my kitchen (which would be cool, I know, but I really don't need more tools in my kitchen).
