connor0770
- Cameron Park, CA/ Reno, NV
Ok guys I got a question for you. I'm getting this really weird and random clunking noise. Basically when I turn my Jeep on it clunks (like my exhaust is banging against something) then it doesn't do it. Once I put it in drive or reverse it makes a metal on metal noise. The best way I can describe it is, it sounds like my driveshaft is spinning freely and has a bad u joint. I really hope it's my exhaust but it really only does this in drive and reverse (when stopped). And when I turn the jeep off it makes the same noise as start up and the keep barely shakes (feels like the exhaust is shaking). What should I check first? Could it possibly be my flex plate loose?
Or could it be my CV in the DS? I get a grinding noise when im on the gas at 50+. It's only when I'm accelerating, not coasting. (so if it's the DS wouldn't it always make the noise since its spinning at the same rate?)
Thanks guys!
Thanks guys!
