lost my keys. i need help
poomero
Tigard
I need some help getting new keys for my jeep. If anyone knows how to make keys or know a cheap place to do it can you please help me out. its a 1990 xj and the dealership said its too old to look up the key code. Thanks.
Is the Jeep locked? Is your door key the same as your ignition key?
The cheapest way to get the ignition key is to go to Autozone and buy a 12 dollar ignition switch key cylinder. It will come with new keys. While your there rent a steering wheel or harmonic balancer pulley puller to pull the steering wheel. I think there are a couple write ups here to walk you through it I know I wrote up a short one. It only takes about 20 minutes or so to change it out. Now for the door locks go to rockauto.com they have them for 11 dollars a peice.
http://www.rockauto.com/catalog/raf...de=1180011&parttype=10007&a=FRc1180011k505127
Buy two of them though. Don't do what I did and go cheap and only buy one. Now my key only works in the driver door, sucks sometimes. Locksmith can rekey the door cylinders that you have but will cost you a lot more.
