bgcntry72
- Queen Creek, Alcatraz
I am finally getting around to removing the 1" block from my rear OME springs and going to a RE 1.25" shackle. I know, I know, but I already had em, and they were steel. Regardless, I currently have an SYE and a 4* shim in the rear. I am a little below my ideal pinion angle, and I want to know how much these shackles will affect that angle before I tear into the springs. I know experimentation is necessary, but if I can avoid it, I will. Should I take out the 4* shim when I take out the 1" block or should I leave it in? I guess my question is, will the 1.25" shackle have an effect of more than 2* on my pinion angle? Thanks for any light shed, as it will cut in half the number of times I have to drop the axle.
:dunno:
:dunno:
