Long Arms-To the crossmember or frame brackets??
Heep
Nebraska
Im about to start making my own long arms-yes Ive searched quite a bit and read arguments about attaching them to the crossmember or making brackets that attatch to the frame so you can drop the t-case without pulling the arms. Strength and ease, what would you suggest to make?
edit: also if I make the brackets, what in terms of steel (would 1/4 plate be sufficient) and design wise would you make em?
i would definitely say make them to the rails cause your axle is gonna want to shoot out without lowers (been there done that)
Bttt
