Check out the B Lee's kit. several friends of mine run it with zero issues, its some what similar to the Cav-fab kits. it uses 3 bolts per side to connect to the frame. apparently there is a nutsert in the frame that needs to be drilled out and tapped and its ready to rock and roll. I have my kit setting in my basement, and its heavy as all get out!
https://bleesoffroad.com/collections/suspension/products/3-link-system
Gonna muddy the water here a bit ...
Given the limited amount of wheeling i actually get to do, and seeing that CavFab is running some sales right now, would it be reasonable to remove the RE drop brackets i am currently running with fixed LCAs and go with CavFab Stage 2 adjustable LCAs?
Nope, but for just a few dollars more you could bet the TNT set-up!
I'd say a little more than a little more.
TnT is 250 for upper and lower CavFab is 180 for just the lowers.
For just lowers pretty sure rwkhaussupply can come close for currie arms.
I got it now....I thought he meant the whole cavfab setup (crossmember, arms, etc) not just the lower arms.
I was gonna say tell me where you got the complete TNT setup for 250 (again, crossmember, arms, etc)...I'll buy 5 of them right now and resell 4 of them to fund a 4 link rear.
