Long Arm Caster Question
d0nnyg77
New London, CT
As far as setting the front caster, spec is 8deg+. We are at 12deg+ right now. Should we adjust the uppers out, lowers in, or in and out evenly on both upper and lower? Also, the kit shows using the greasable bolt for the lower arms in the center frame mounted bracket. However, there is a greasable heim joint at that connection. The Johnny Joint at the lower mount at the axle has no greasable areas. Is this right? BTW, it's an XJ 6" Full Traction Long Arm kit. Thanks.
