mako my day
- Aliso Viejo
Why did you go back to the stock fan clutch?
well bad experiences get talked about and good ones get forgotten..
I have had my original thick 2 row american eagle (Same company and facility as champion) all alum in since 2011 and ran: some of KOH, glen helen, Bluewater desert challenge, a few very hard Calico trips and a few trips to salton sea, as well as about 2-300 miles around town and some very hard shock testing sessions. I have not had to open my cooling system other then to replace a motor right after KOH 2012. I have not touched anything cooling. I have never seen temps over 185, and never had a concern on temps. I have ran a sand wash that was about 1ft deep soft sand that most 2wd would stop and have to dig out of, at about 45mph floored with a 4.7+ 10.5-11:1 comp stroker on 116oct fuel, for over about 3 min straight, without temps rising. I run all longacre pro gauges, and have both a temp gauge and a 210 idiot light. So know its never overheated and all has been good.
I LOVE my flowcooler pump, All alum rad (thick 2 row), ZJ v8 fan clutch, 10 curved blade stock elec fan, stock shrouds, and 180deg t-stat, and a I think a 20lbs rad cap. Never failed me yet...
On another note. I have seen 3 fans melt, engines loose head gaskets and total loss, due to 3 elect fan setups. I have seen plastic endcaps crack within a year. I have seen stock radiators open up at brazed connections. All of which are bad experiences that like I said get remembered. But I know that the general public has had good experiences with stock stuff. If in a stock Jeep and maintained.
the ZJ fan clutch is a bandaid.
and it sounds like a freaking jet powered helicopter trying to take of
But the fan power helps pull me thru faster
