MTN4X4
- Running Springs, ca
any good , what are thay good for,
buddy of mine just gave one to me.
junk or treasure??????
MTN4X4 said:how do you pick rods,
whats size metal to what size rod.
how thick to how thin can you weld with a stick welder?
Depends on what the shop produces...
Sticks a great way to weld a fence or trailer outside, but almost nothing automotive should be sticked (IMO). Gas sheilded MIG is perfect for 99% of anything you'll ever want to weld. Thats not to say that stick can't be used, but MIG is the prefered shop weld.
Just my 2 cents.
If your shop has no walls, or rolls on wheels then stick is excellent!![]()
stick has a place in the off road manufacturing process as well. a lot of our aftermarket products can be stick welded. when you get into thicker items like skids and such, stick welding can give you a stronger bead and better penetration without having to do multiple passes as with mig. but stick is not the best process to use on sheet metal. for that mig would be best.
not true. with mig, you have to run up to THREE times the heat to get the same penatration. ok if you can spend upwards of five to ten thousand times the price of a good stick. the reason many shops use mig is the speed like you said, but like you said, you are running upwards of 700 amps, where for the same thickness of steel you only would need about 300-350 amps. with thicker plate, you also need more weld for the same streangth as stick, unless your company is forcking out a lot of money for very high doller wire. I too worked in a structural steel welding shop, and i dont know about you, but they used the cheapest, s***iest wire they could get their hands on. the stuff wouldnt even beed right.
