RWKHausSupply
- yorba linda, Cali
Lincoln weld pak 3200HD MIG / Wire feed welder
Used but in excelent fuctioning condition and no issues in operation. No chassis damage, all cables are in perfect condition and gun has no issues.
Specs are
115V - 20amp input
25-135amps
Rated to 1/4" Mild steel - single pass.
I have used this to build / fab many items and yet to ever have a weld fail. I have a TJ that even rolled off a trailer at 70mph and the tube (1.75x.120) bent/ripped but the welds never broke. Suffecient penitration on cage work, axle brackets, frame mounts, etc.
Low enough amp seting to weld sheet even.
I will sell just the welder with a full spool + of flux wire for 250$ but throw in a regulator with semi full 75/25 mix tank and a 10lbs Large spool of solid for 300 total.
Your welcome to test/use it before you buy it. That doesnt mean come do your cage / rockers to test it and not buy it though
Located in Yorba Linda.
Specs are
115V - 20amp input
25-135amps
